Headlights!
Posted: Fri Jun 08, 2012 1:43 am
by Sam-NI
I have done the relay mod, and installed 2 UK spec 60/55w
My headlight alignment is way out!
Is there only 2 adjustment screws per side on the NC30?
MOT is Friday evening, so need some help ASAP!
Re: Headlights!
Posted: Fri Jun 08, 2012 2:33 am
by Deviant400
yes 2 screws on each light one at the top and opposite bottom corner i belive
Re: Headlights!
Posted: Fri Jun 08, 2012 11:02 am
Sam-NI wrote:I have done the relay mod, and installed 2 UK spec 60/55w
How did you make the bulbs fit?
Did you use adapter rings?
Did you cut the piece of tab away and alter the lower tabs to make them fit right?
Re: Headlights!
Posted: Fri Jun 08, 2012 1:58 pm
by Sam-NI
I just bent the lower 2 tabs in. What should I be doing?
Re: Headlights!
Posted: Fri Jun 08, 2012 6:24 pm
Sam-NI wrote:I just bent the lower 2 tabs in. What should I be doing?
Oh then it'll never line up!
Unless your using adapter rings then You need to cut some of the bulb and use a nail to support the bulb, otherwise it won't line up right.
http://cbr250.com/forum/thread-284.html
Here is the nail guide.
You'll notice that theres a cutout in the outer ring of the original H4R (35w) bulb too. the H4 doesn't have this I filed down the indent on the inside of the headlight as it's easier than cutting the bulb.
