wiring for reg/rec
Posted: Sun May 27, 2012 4:50 pm
by rpg
hi there, my nc30 had a r1/r6 reg/rec put on but the original connector block was snipped off in favour of spade connectors. i am putting it back to standard after the electrical problems, but where do the wires go in respect to the underside of the standard reg/.rec ? ive got 3 yellow wires and i red and blue.
any help much appreciated.
Re: wiring for reg/rec
Posted: Sun May 27, 2012 8:54 pm
by vfrman
Not sure if this helps, but this is the pin-out of the reg/rec on my 98 Fireblade... The third yellow wire goes in that smoldering hole in the upper right of the connector.
Posted: Sun May 27, 2012 10:20 pm
by nazzurro_19
The red wire goes on the right pin the green on the left and the 3 yellow go on the bottom in any order it doesnt matter
Posted: Mon May 28, 2012 11:52 am
rpg wrote:hi there, my nc30 had a r1/r6 reg/rec put on but the original connector block was snipped off in favour of spade connectors. i am putting it back to standard after the electrical problems, but where do the wires go in respect to the underside of the standard reg/.rec ? ive got 3 yellow wires and i red and blue.
R1/R6 reg/rec is miles better than stock... really really worth keeping.
