Page 1 of 2
using hylomar blue on carb bowls
Posted: Fri May 25, 2012 5:57 am
by krisztian_andre
Do you take out the old rubber gaskets and put hylomar in the groove instead or how do you do it? I'm afraid I'll block something in the carbs with the squeezed out sealant after assembly.
Re: using hylomar blue on carb bowls
Posted: Fri May 25, 2012 6:10 am
by Cammo
I used to recommend using sealant but you do run the risk of it causing blockages, though it never caused me issues in 3 years of racing.
These days I use Rick Oliver's replacement o-rings, only a few quid for a set of 4, bargain!
Posted: Fri May 25, 2012 7:52 am
by krisztian_andre
Shipping takes ages, so I only order from the UK if I have time and getting several things at once. Cammo did you leave the old gasket in when using the sealant?
Posted: Fri May 25, 2012 9:33 am
by The Novice
Yes - i always left the gasket in when using the hylomar blue - but as cammo said, order a load of the o rings anyway, saves the mess everytime you need to open and reseal.
Posted: Fri May 25, 2012 9:57 am
by abrmoto
Dont do it, blue hylmor will turn blue jelly and gum up carbs, did it on my petrol tap few years back, never again!!
Posted: Fri May 25, 2012 10:45 am
by missis sumner
Personally, I would use Hylotyte Red (Hermetite), because it's semi hardening.
Posted: Fri May 25, 2012 10:53 am
by abrmoto
missis sumner wrote:Personally, I would use Hylotyte Red (Hermetite), because it's semi hardening.
:plus:
Posted: Fri May 25, 2012 11:12 am
by The Novice
To back up what Abr and missis said - I did get some of the blue gunk in my carb bowl ! but i used to slap a load on as i was sick of the petrol peeing out ! if your careful, blue does it just as well.
Posted: Fri May 25, 2012 11:46 am
by CRM
a thin smear of grease to seal.
Posted: Fri May 25, 2012 12:43 pm
by porndoguk
CRM wrote:a thin smear of grease to seal.
Same here red rubber grease here used to use hylomar but switched to red rubber.
