Fan not working .. Tests?
Posted: Thu May 24, 2012 1:31 pm
by nazzurro_19
Ive been out and about on the bike all day today and while riding bikes sat around 90° , i then went to my garage and while unlocking the door left the bike to idle , i came back to the bike and notices the temp needle was now well over 90° and the fan wasnt kicking in
So is there any wa to test the fan switch or temp sensor , cause i dont want to start buyin things and changing if im hittin it from the wrong angle
Re: Fan not working .. Tests?
Posted: Thu May 24, 2012 1:51 pm
by viper_biker
Temperature sensor must obviously be working as it's showing on your clocks. As for the fan, make sure the connectors are clean and secure and you can test it by jumping the fan off your battery.
Posted: Thu May 24, 2012 2:03 pm
by nazzurro_19
Yeah true , im now guna go check the fuse and take the fan connectors apart etc test em and clean em
Posted: Thu May 24, 2012 2:32 pm
by spud
nazzurro_19 wrote:Yeah true , im now guna go check the fuse and take the fan connectors apart etc test em and clean em
if you get stuck and cant slove it , i can pop over and have a look for you as only a 20 mins job to test and fix , you prob find that its the fan switch thats gone , can get a new one from rick o or c j ball ,
plus well worth cleaning your rads out and degrease them as well , as they build up with shit in them ,
done this to mine and made a differents
sam
Posted: Thu May 24, 2012 2:49 pm
by nazzurro_19
Spud you about to pop over now? That way you can confirm if you think its the same prob then i can go buy correct parts
Posted: Thu May 24, 2012 2:56 pm
by spud
nazzurro_19 wrote:Spud you about to pop over now? That way you can confirm if you think its the same prob then i can go buy correct parts
yep im about now chap as finished work for the day ,
pm me ur post code and house number and will pop over in a bit
sam
Posted: Fri May 25, 2012 7:17 am
by magg
Note the fan temp switch is not related to the temp gauge, i.e. working temp gauge does not mean working fan temp switch.
