NC30 - cam degreeing logic
Posted: Sun May 13, 2012 6:50 am
by lukemillar
Hey
I'm in the middle of installing some new camshafts (not a stock profile) and I wondering if anyone can confirm my gear-driven cam logic.
There are 40 teeth on an NC30 camshaft. So 360 degrees / 40 teeth = 9 degrees per tooth
Therefore, slipping a camshaft 1 tooth will result in an advance or retard of 9 degrees? Been scratching my head for hours on this as that is not what the numbers are telling me. I think it is to do with to profile of the cam being asymmetric (which I'm waiting to have confirmed), but would also be great if someone can tell me the maths is sound and I'm not being thick!
Luke
Re: NC30 - cam degreeing logic
Posted: Sun May 13, 2012 7:28 am
by jetblack
Surely 9 degrees is way too much? Don't you need adjustable cam gears so you can dial in 1 or 2 degrees?
Posted: Sun May 13, 2012 8:04 am
by krisztian_andre
I can definitely confirm that 360 / 40 is in fact 9
Posted: Sun May 13, 2012 8:21 am
by lukemillar
jetblack wrote:Surely 9 degrees is way too much? Don't you need adjustable cam gears so you can dial in 1 or 2 degrees?
Yes and no. I'm just trying to install these cams straight up, but need to confirm that I can't do that in their current state, so I'll need to get them slotted.
Posted: Sun May 13, 2012 9:21 am
by 999Gomerz
It may not be 9 degrees. It would depend how many times the camshaft turns in relation to the crank. If the cam turns twicè for every 1crank turn then it wold be 4.5 degrees per tooth.
Posted: Mon May 14, 2012 12:18 am
by lukemillar
It's the other way round - the camshaft turns once for every 2 crank rotations.
I think I have found the issue- It is an asymmetric profile; I just need to alter where I am taking my measurements from.
Posted: Mon May 14, 2012 10:31 am
by 999Gomerz
lukemillar wrote:It's the other way round - the camshaft turns once for every 2 crank rotations.
Are you measuring at 1mm lift?
Posted: Tue May 15, 2012 1:04 am
by lukemillar
999Gomerz wrote:lukemillar wrote:It's the other way round - the camshaft turns once for every 2 crank rotations.
No, I was initially measuring 1mm either side of max lift to get the centreline. The lobe profile initial opening/closing is where I switched to e.g 1mm lift. However, with the cam holders being the way they are, getting a dial indicator in there is a real PITA! Anyway, I'm sorted now, I finally got some accurate and consistent numbers, which just confirmed what I suspected in the first place, which is I need to slot the cams.
