Cleaning those crappy sections
Posted: Thu May 10, 2012 9:38 am
by Mavirick
Hi there
after a few years of having my bike i`ve decided to rebuild the 35 completely (build thread to come)
what do you guys use to clean those hard to reach places and stubborn grime expecially on the motor and the inside front of the frame
Ive tries clean green (worked so so)
petrol (expensive but works really well but even then there ate these sections that just don't get clean
another question whats the best way to polish the headers and the frame and swing arm to get the best results
thanks MAV
Re: Cleaning those crappy sections
Posted: Thu May 10, 2012 12:40 pm
by ibby4585
Gunk is brilliant but expensive. Get yourself a small garden pump spray and fill it with parafin then get some brushes, plastic ones and brass wire ones and shit loads of rags!!
Enjoy!!
Posted: Thu May 10, 2012 2:56 pm
by Mavirick
Does pariafin really work that well
Posted: Thu May 10, 2012 2:58 pm
by ibby4585
It's the cheapest. Gunk is the best I find, maybe do 50/50 mix to cut the cost.
Posted: Thu May 10, 2012 3:03 pm
by lizard821000
yup, no easy way im afraid, just takes time and effort, worth it though. i couldnt believe how much shit come off mine.
if your polishing the frame for a mirror finish you ll need wet n dry through the grades and some compound on a wheel to speed things up, autosole is always a winner too! if its the brushed look your keeping , i found fine wire wool worked wonders.
Posted: Thu May 10, 2012 3:08 pm
by Deviant400
SOC by rock oil is pretty good too its a tad cheaper than gunk , well it is at my local shop anyway,
personally i wouldnt mirror polish frame and swinger , it looks really good but you'll really need to keep on top of it to keep it that way
Posted: Thu May 10, 2012 3:39 pm
by Vfr400/tbird
Might sound strange but to achieve a polished frame on my Nc21 i used a fine grit wet/dry sand paper and autosul together at the same time i found that once it went through the lacquer it went real shiney real quick
Its not a method i'd heard before but tried it and it works, i never used a wheel or any special compound just autosul and wet n dry about 6 quid's worth in total!
Posted: Thu May 10, 2012 9:23 pm
by porndoguk
Brake cleaner, parafin,
And the best but be carefull it doesnt go near plastic, powder coat and paint = carb cleaner
