NC29 Charging Problems
Posted: Mon May 07, 2012 3:10 pm
I'm getting some charging problems, and I'm posting here cos I'm stumped...
Any suggestions of more things to test, or what the problem may be?
- Over time my battery runs flat.
I can bump/jump start it and it will run off its own power, but as soon as the revs drop or I turn the lights on (anything with a high power usage) the bike dies.
I'm not measuring a charging voltage higher than the battery's own voltage (ie the voltage across the battery measures the same whether the bike is running or not)
The resistance across the yellow wires for the alternator is 1.5 ohms.
I can't detect a current leak when the bike is off, and checked the whole electrical system for shorts. Including the red/white wire between reg/rect and starter relay (I read that it can decay)
Recently replaced battery and regulator/rectifier.
