wanted 1 3/4 inch steel/stainless bar
				martynfzr
okay then i have a fzr400 with a stainless micron sytem from a fzr600 the only problem is that the collets that fit onto the head are mild steel and are rusting badly so im going to get some new ones made up but i need the materials first
				Petetheengineer
Re: wanted 1 3/4 inch steel/stainless bar
hi there i might have some plate but it depends on how your getting them machined but i might also be able to get some bar but i would have to work on it. do you know what grade of steel you need 316 or 17/4 or do you need something a little harder 9000 or something i use alot of stainless but you might be better of going for pipe unless you have access to a lathe. let me know how much you need and ill get some for you. if you need any help with technical drawings i can provide you with BS drawings that you can give to any machine shop with the correct tolerances and fits.  im sure we can sort something out
					Last edited by Petetheengineer on Wed Sep 10, 2008 12:16 am, edited 1 time in total.
Interesting Pete ... I bought my FZR near Gatwick.
				Petetheengineer
i bought my fzr near gatwick as well must be a hot spot
Mine's a black 3TJ .... is yours similar ???
I saw you were looking for a project ...
				Petetheengineer
no mine is a 1wg 3en2 or something like that.
well im in the process of getting a track bike together so looking for a dismantled bike or salvage.
If i dont find any i have the option to build it from parts from my local friendly breakers.
				Petetheengineer
i have a variety of stainless so just let me know what size
				martynfzr
1 3/4 inch bar either stainless or normal steel bar
Shirley it's a metric bar ???
