NC 30 Rear wheel stuck on shaft
Posted: Tue May 01, 2012 9:31 pm
by Ashspider
Undone the nut but the wheel is solid. Any suggestions for easing it off.
Thought about a bit of steel behind the spokes on the drive side an another longer piece going across the shaft with the nut back on to protect the end. These pieces will then be tied together with threaded bar to gradually pull them together and pull the wheel off the shaft. Tried a rubber hammer and a bit of penetrating fluid but no joy.Am I missing a simple solution. It has been stood a while.
Re: NC 30 Rear wheel stuck on shaft
Posted: Tue May 01, 2012 9:33 pm
by porndoguk
Ashspider wrote:Undone the nut but the wheel is solid. Any suggestions for easing it off.
Thought about a bit of steel behind the spokes on the drive side an another longer piece going across the shaft with the but gack on to protect the end. These pieces will then be tied together with threaded bar to gradually pull them together and pull the wheel off the shaft. Tried a rubber hammer and a bit of penetrating fluid but no joy.Am I missing a simple solution. It has been stood a while.
Block of wood and twat in from the sprocket side, rotate wheel in quarters and hit it again its a common problem
Posted: Tue May 01, 2012 9:35 pm
brute force....twat it
Posted: Tue May 01, 2012 9:37 pm
by Ashspider
Better get a bigger persuader then
Posted: Tue May 01, 2012 9:40 pm
by Deviant400
and some copper slip to rub on the contact points when you put it back on
Posted: Tue May 01, 2012 11:01 pm
by hardnutdvd
serious amounts of brute force at quarterly turns.
Posted: Wed May 02, 2012 6:01 am
by scooble
I got a bearing puller and a cylindrical tube to push against the axle. mine was proper tight and took a big spanner and lots of torque to get it off. Eventually it popped off and I gave the shaft a good clean with emery cloth and re-assembled with copper slip
Posted: Wed May 02, 2012 7:08 am
by CRM
i bet some clown has powdercoated the wheel and not bothered to clean up the inside mating surface of powder when they but the wheel back on.
brute force is the only way
make sure you clean the inside of the wheel up with a dremel after to stop it happening again
Posted: Wed May 02, 2012 3:57 pm
by VFRkieran
porndoguk wrote:Ashspider wrote:Undone the nut but the wheel is solid. Any suggestions for easing it off.
This is exactly what i did last week and it works a treat
