Fitting tyga rearsets
- 28hodge
Hi need some guidance please,
Bought these second hand and thinking a bit might be missing, on the rear brake there is no provision for a spring to make the rear brake return, I'm pretty sure there should be but on these ones there is nothing, can someone post a pic up of their right hand rearsets please so I can see if I'm being thick or if I'm missing a bit!!
- alexwitham
Re: Fitting tyga rearsets
PM me your mobile number and I'll send you one over.
- 28hodge
Sent cheers alex
I have no spring on my tyga rear sets, non of the race ones come with or need one really, you don't have a spring on front brake lever.28hodge wrote:Hi need some guidance please,
- alexwitham
No spring on mine. The level returns without the need of a spring. IIRC wasn't the spring just for the plunger for the rear brake light?
- 28hodge
Thanks Alex,
That's ok then, if it's not meant to have have one then that's that sorted, wasn't sure if you needed a spring return to pass scrutinering as you do in motox!
- Bike owned: RVF400
Yeah, the spring is the just to activate the brake light when you're using the rear brake, the pressure inside the master cylinder should return the lever back to the original position when you take pressure off of the lever.
