URGENT HELP "Cant Find Neutral"
Mavirick
- Bike owned: NC35
Hi there chaps
I recently purchased a RVF400 NC35 1997 and i have a problem with finding neutral
If the engin is NOT running its perfect slips in like a hot knife through butter,
but as soon as the engin is ON idling it jumpes straight into 2de doesnt matter how gentle or hard ou try
Please help me solve this problem ASAP as his is really irritating
Thank you
MAV
Thank you
MAV
Re: URGENT HELP "Cant Find Neutral"
Blip the throttle and slot in common thing on honda engines.
Mavirick
- Bike owned: NC35
porndoguk thanks for the reply
I know this from my previous VFR but this is different it doesnt work Blipping the throttle
Thaks MAV
Thaks MAV
It is user error still mate..
Are your dots lined up on the gear lever? Are you sure the cable is not too right? Does it go in when rolling forwards?
with slight upwards pressure from first, if raising the rpm to say 3000rpm and letting it drop doesn't let it slot in then as above,
check clutch cable is adjusted properly as well as gear-lever rod.
If your clutch is badly worn / adjusted it will make it difficult, as well as the gear lever
Mavirick
- Bike owned: NC35
thanks for the replies Ill have to chech this as soon as i get home from workNeosophist wrote:with slight upwards pressure from first, if raising the rpm to say 3000rpm and letting it drop doesn't let it slot in then as above,
the cluch lever takes all the way on the end (fingertips) doesnt matter how you ajuct it .........could this just be that the cable is wrong or streched
thanks MAV
Le_Blur
- Bike owned: 1990 NC30
Have you tried backing off the lock nuts at the other end of the cable?
slowsport
- Bike owned: NC35
hi, this probably isn't much help to you but i had the same problem when i first bought my NC35, in the end i replaced the clutch plates and had to smooth the clutch basket fingers as they had small wrinkles/wripples. since i had done this i can always select neutral easily
Mavirick
- Bike owned: NC35
I havnt to be honestLe_Blur wrote:Have you tried backing off the lock nuts at the other end of the cable?
Mavirick
- Bike owned: NC35
thanks for the info the cluch is perfect i think its the cable ill have a look when i get homeslowsport wrote:hi, this probably isn't much help to you but i had the same problem when i first bought my NC35, in the end i replaced the clutch plates and had to smooth the clutch basket fingers as they had small wrinkles/wripples. since i had done this i can always select neutral easily
