Where is the heat sensor???
Posted: Mon Apr 09, 2012 6:55 pm
by Stuster
Hi guys ( Again )
Been advised off a guy that the reason my CBR cuts out may be due to the heat sensor. Where is this on a 89 CBR 600 F1?
Re: Where is the heat sensor???
Posted: Tue Apr 10, 2012 9:42 am
by kiwi racer
?????????? a what !!
Posted: Tue Apr 10, 2012 11:54 am
by thunderace
kiwi racer wrote:?????????? a what !!
I refrained from replying earlier because I was too busy pissing myself with laughter :lol:
Posted: Tue Apr 10, 2012 4:18 pm
by Stuster
:oops:
Posted: Wed Apr 11, 2012 12:16 am
by RICKNC31
Hi you have a heat sender on the rad that moves the temperature gauge you have a thermostat in the coolant system that alows more flow or less flow of coolant but you will not have a heat sensor on a 69 CBR600 there are much more modern bikes that would have a heat sensor in the system to do with fuel injection ect but you will not have one in your CBR600 so if you are having problem"s you will have to look elswhere ie ignition plug"s faulty switch ect hope this helps Rick
Posted: Sat Apr 14, 2012 7:47 pm
by Stuster
RICKNC31 wrote:Hi you have a heat sender on the rad that moves the temperature gauge you have a thermostat in the coolant system that alows more flow or less flow of coolant but you will not have a heat sensor on a 69 CBR600 there are much more modern bikes that would have a heat sensor in the system to do with fuel injection ect but you will not have one in your CBR600 so if you are having problem"s you will have to look elswhere ie ignition plug"s faulty switch ect hope this helps Rick
Thanks very much for the reply, will get on this tomorrow and see if this helps. :pray:
