Page 1 of 3
Zxr400 forks
Posted: Sun Mar 25, 2012 9:10 pm
by bikemonkey
Seen some zxr400 forks for sale, but the seller doesn't know which model they are from.
I need the L model forks to be able to fit them to an NC30 right?
Is there any way of telling which model the forks are from?
Speedy reply will be greatly appreciated!
Re: Zxr400 forks
Posted: Sun Mar 25, 2012 10:51 pm
by lizard821000
i just missed out on a set off L model forks for another model fork conversion im doing ..... seems they are quite sort after for a few diff bikes then. i know a guy who has 3 sets , iv asked if they are L or H model ones. when i get an answer and buy mine, ill be sure to pass you on to him.
as for telling the diff......im unsure mate tbh.
try here for a clearer answer mate....
http://www.rgv250.co.uk/forums/index.ph ... ntry405935
Re: Zxr400 forks
Posted: Sun Mar 25, 2012 11:37 pm
by hunter
Well i can tell you that the h forks are around 25mm longer than the L model.
Dont know if that's any help.
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 4:14 am
L are indeed longer, the L SP forks would be my choice if they were available, there 3 way adjustable as opposed to the normal 2 way
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 6:14 am
by scooble
The H model used 300mm discs and the L used 310mm discs, so the caliper mounting is different.
Also, the main upper fork leg diameter is different, the H is about 1mm smaller in diameter.
FYI ZX636 and ZX6R forks fit into L yokes
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 6:26 am
by bikemonkey
Thanks for the replies guys.
I guess telling the difference without having a set of each infront of you isn't easy, exact measurements for both models length etc aren't coming up on google or anywhere either.
Lizard, yeah if you could point him in my direction i'd be grateful :up:
Scooble, could I use the fitting kit from rick oliver to put a pair of zx636/zx6r forks on my NC30?
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 7:53 am
by mo haggs
Yes you can. But you still need the L model yokes.
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 8:07 am
by lizard821000
no problem bikemonkey, im chatting with the guy later today hopefully so llets hope they are all the L model .
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 11:07 am
by bikemonkey
Yes let's hope the forks are l models!
Would I also be right in thinking that besides the yokes and RO fitting kit the forks are a straight swap?
Re: Zxr400 forks
Posted: Mon Mar 26, 2012 11:18 am
by mo haggs
To the best of my knowlage the rick o kit allows you to fit the zxr L yokes ( inc stem). This allows the fitment of zxr L forks.
But the zxr yokes will take zx636 or zx6r forks as a straight fit.
