Page 1 of 2
Clutch cable routing
Posted: Tue Mar 13, 2012 11:04 pm
by makz2008
ok so my clutch cable snapped on friday and i ordered a replacement from honda dealer the same day which im hoping will arrive tomorrow...
i replaced the cable when i got the bike in may, with a non genuine part which wasnt very good, and now that im going to be using a genuine part id like to route it the correct way. the previous owner of the bike informed me that he had been using the bike with it routed wrong in the first place so its been wrongly routed for a while now
if anyone has a pic that would be great, diagrams and descriptions are also appreciated ...
thanks
maks
Re: Clutch cable routing
Posted: Tue Mar 13, 2012 11:29 pm
by Deviant400
Posted: Tue Mar 13, 2012 11:51 pm
by makz2008
thats perfect thanks
Posted: Thu Mar 15, 2012 1:08 pm
by makz2008
Just got my cable from honda dealers but before i fit it i want to know if the cable needs lubricating at all?
or shud i just whip it on
Posted: Thu Mar 15, 2012 1:14 pm
by Deviant400
never lubed mine before it went on , never had a prob with it (not sure if your meant to lube a fresh one actually)
Posted: Thu Mar 15, 2012 1:22 pm
by makz2008
thanks just going to fit it as it is then
Posted: Thu Mar 15, 2012 3:29 pm
by ludacris
its a brand new cable...you need to lube it
Posted: Thu Mar 15, 2012 11:22 pm
by makz2008
Ive just seen that now I feel like taking it off, what would i use to lube it? ive never lubed a cable before
Posted: Fri Mar 16, 2012 10:35 am
ludacris wrote:its a brand new cable...you need to lube it
I've never lubricated clutch cables on VFR's.
Are they Teflon coated inside? If they are you don't need to and shouldnt' lube them as it will break down the teflon and reduce the life of the cable.
There is nothing in the NC30 service manual schedual about lubricating the clutch cable either.
Posted: Wed Mar 21, 2012 12:07 pm
by ludacris
He has an OEM cable, I doubt it would have teflon. Sorry, I merely meant to suggest it as a way to prevent premature wear on the cable. I've come across new cables binding and sustaining heavy wear/fatigue due to being installed without some adequate lube (obviously others would have different experiences, so should also be taken into account)...
I have aftermarket cables so I just made sure I greased the ends before installing but personally I would do it on an OEM cable.
