Not having much luck ... Help :(
- Bike owned: Honda NC30
Ok now before people start sayin this is my fault , i will admit i should of checked but with the hassle of insurance and tax it totally slipped my mind
Anyway , riding to work today as the weather is nice my oil light starts to flicker , i stoped and put the bike on the stand and the light flicked even more so i turned it off and turned it back on (my lights been a bit funny lately neutral etc) and it started and worked fine so i got to work and with the bike upright i undid my filler cap wiped it and put the stick back in (resting not screwed) pulled it out and completely dry!!
How easy/quick is it to do an oil change and filter? I also need to ride the bike 1.8 miles home will this be ok as the light isnt constantly on
Cheers guys n sorry for all the qs but i was told this bike was mechanically mint and maintained
Also is there a way to check for oil leaks etc other then just visually as im now concerned the bike could be rough as hell and new oil will show new faults ... Only 2nd time on the bike and 5 days of ownership .... Sheessszh
- thunderace
- Bike owned: R6, YZF600R
Re: Not having much luck ... Help :(
TBH, the first thing I ever do with a second hand bike is an oil and filter change.
The problem is, you don't know how long the oil level has been this low and you can't accurately estimate if any and how much damage has been done.
I would be getting myself out at lunch to pick up some oil at least to get you home, even if it's only a litre of Tesco Value car oil. Then don't ride the bike again until you've done a full oil and filter change. You may get a bit of clutch slip using car oil but a new set of friction plates is much cheaper than a new engine.
Stick some bike oil in it, you might get away with it.
The missus has picked me up a new filter and oil and im going to do it at home tonight
But she cant get to my work and i cant get the bike home other then to ride it
- Speedy
- Bike owned: RVF400RR, ER6n
Not having much luck? I think that may have changed!...
It seems you were lucky the bike got to your work place without seezing; DO NOT START IT AGAIN, at least not until you put some oil in it.
You've done the oil level check correctly and as you've found out, it's well below minimum. Either top up with same type of oil you had (if you know which) or drain out the remaining old stuff and refill with some 10W40 Semi-synthetic oil.
You can worry about the oil filter later, but if you're going to change the oil before riding home, all you have to do is open the filler cap, undo the drain bolt from under the engine (17mm hex if 'm not mistaken) and let it drain out. Replace the drain bolt (DO NOT OVERTIGHTEN) (35Nm of torque is recommended), fill up with fresh oil and check level again.
Fire up the bike keeping an eye on the oil light, it should go off after a second or two of firing the engine. Let it warm up if all is well, then switch off and re-check the oil level; top up if needed.
You'll need 2.4 litres of oil, 2.5 when the filter is changed.
nazzurro_19 wrote:The missus has picked me up a new filter and oil and im going to do it at home tonight
It is a sketchy idea to ride it... you might get lucky..or more than likely, you will do it some damage that will kill it now, or cause it to have terminal issues.
I don't believe that you cannot get some oil and throw it in the bike to get you home! Or even that you can leave it there and blag a lift from someone at work - are they all bastards? Your bike might seize and kill you..it might not..it may even just have engine failure and then how are you gettng home or to work for next week?
Get some oil...put it in the bike til it reads on the dipstick...risk riding it home but at least you;ll have oil pressure. The light is not a level light like in some bikes, it is pressure. Oil pressure is all that keeps the crank tip top
- alexwitham
Dude.
If you want me to come round and give it a once over, do the oil and filter for you then just drop me a PM. I've had 3 NC's now, ridden 4 and have rebuilt 2 so I can tell a shitter when I see one.
- Man_Named_Dave
- Bike owned: NC30(K)
1.8 miles is a pretty short walk. Better to stroll home and come back with some oil tomorrow.
- Bike owned: Gsxr 1200 turbo.nc30
I feel bad enough, allready having week from hell new baby, sick wife an now the nc30 i just sold this one! is causing so much grief its untrue. its no way a shitter i just spent whole winter refurbing everything??? WTF WHY does this stuff happen, neutral problems warning lamps playing up, Rode superb to mot and five or so miles i ran it. I HAVE OFFERD a refund if hes not happy in the end just to be fair.!
Its an honest bike thats been off road a while i know the last two owners and its allways been serviced and thats why it survived thus far.
Sorry chap. all i can say hope things get better rather than worse. fula.
Cheers alex for the offer :)
And just an update guys i pushed the bike to my mates house and we took the panels off checked for leaks etc , changed the oil filter all new oil and shabang its all ood just come back been out for last hour or so and ill check oil in the mornin as its dark now
But so far so good n i dont wana refund i like this bike :)
