Battery
Posted: Fri Feb 24, 2012 10:07 pm
by steve92
Can anyone recommend a good battery to use for running total loss?
I got a race subframe now the standard battery is too big, so i'm looking for one thats going to last a day on track.
The battery tray measures 120mm x 70mm. What bike would use this size just so i know what i should be looking for?
I've been looking at the motobatt ones on ebay, whats your thoughts on these?
Thanks Stephen.
Re: Battery
Posted: Sat Feb 25, 2012 4:23 pm
by Malc
Stephen, even your larger YTX9 would probably struggle to do a whole trackday, assuming the usual 7 x 20 minutes. With a smaller one, I'd guess around 2.5Ah given your dimensions stated, you'd be much better advised to make provision for charging between sessions or refit the charging electrics.
A YT4L-BS is about 120 x 70 x 80 in size, and generally rated at 3Ah.
Re: Battery
Posted: Sat Feb 25, 2012 4:51 pm
by steve92
Thanks Malc,
is it ok too charge off a genny, how does most people run all day?
I know charging batterys for cordless tools on a genny wrecks the charger.
Re: Battery
Posted: Sat Feb 25, 2012 9:14 pm
by kevprojex
You will run for a full trackday on a ytx9 with some to spare , i have run total loss on my last nc30 and have total loss on my nc35, i even forgot to re charge my nc30 before a trackday and it still ran ok . use a good quality battery and avoid cheap shite.
Re: Battery
Posted: Sun Feb 26, 2012 6:37 pm
by Malc
kevprojex wrote:You will run for a full trackday on a ytx9 with some to spare , i have run total loss on my last nc30 and have total loss on my nc35, i even forgot to re charge my nc30 before a trackday and it still ran ok . use a good quality battery and avoid cheap shite.
Kev, does yours have a fuel pump? Mine did which I guess would explain why I had to recharge between sessions.
Yes Stephen, running Optimates and like iff gennys is fine and a very common site in the paddock.
