nc23 coil problem
Posted: Mon Jan 30, 2012 10:53 am
by sewelly1989
hi,
im bit of a beginner to building a race bike sorry if it sounds silly or simple.
heres the problem , i fitted the race ignition from gf, it will run but on 2 cylinders 1/4 but no spark on 2/3 ive put the multimeter on and found 12v getting to the coils n thats as far as ive got so i dont really no what to do any ideas please??
thanks
adam
Re: nc23 coil problem
Posted: Thu Feb 02, 2012 9:37 pm
by Variablevalves suck
It could be the actual coil but first check the HT wires are in the coils and caps nice and tight.
Switch the coil from 1/4 over and see if the problem switches over, if so you need to start working your way back toward the cdi.
Posted: Thu Feb 02, 2012 9:51 pm
by petrolhead19
sewelly1989 wrote:hi,
thanks
adam
As said in previous thread you made mate, coil #2 is wrong, firing order of coils is 1-4-3-2, the way you say you have your coils is 1-4-2-3 which is wrong so its going to run rough and not fire properly lol.
The reason for it not running on 2 and 3 is because the leads are wrong way round, swap them so coil #2 is in 3-2.
Trust me pal i have built enough of these bikes to know lol :D.
Change the second coil and report back to me, probably to say thanks :) lol
Adam
Posted: Thu Feb 02, 2012 10:54 pm
by LITTLE=ONE
taken from the haynes book of lies ?
but try adams way , as his bike is running
bighug
:rocks: :rocks: :rocks:
Posted: Fri Feb 03, 2012 11:52 am
by tanuki
so....exactly like I said then.
tanuki wrote:are you %100 sure?
I dont know about the 23 but the 29 is left coil plugs 1 & 4 right coil plugs 2&3
Posted: Fri Feb 17, 2012 9:18 pm
by sewelly1989
just to let you all know that i re-wired my bike and had voltage everywhere correct,
so i checked the pickup manually i had from graeme france and one of the pickup is not working :cry: = problem solved :grin: thankyou all for your help
Many Thanks
Adam
Posted: Sat Feb 18, 2012 2:00 am
by LITTLE=ONE
and the coils are 1-4-3-2 or 1-4-2-3
Posted: Sat Feb 18, 2012 11:43 am
by GF Racing
I remember you said it was all working before your friend worked on the loom ... something odd has happened ....
Best call me from next Wed. on .... busy at hospital until then.
Posted: Mon Feb 20, 2012 3:34 pm
by sewelly1989
its only worked and ran on 2 cylinders, we did work on the loom and now the loom is sorted and went through dyna2000 troubleshoot ..
yeah ok ill ring wed.. :smile:
Adam
