Seized Carb Screws!
Posted: Mon Jan 23, 2012 9:57 pm
by MostyVFR400
Just following the Carb Jetting Guide, and have got to the point where I'm taking the carb slide covers off. Some of the screws are coming undone ok, but some are well and truly seized. Not wanting to round off the phillips heads. What's the best way to go about getting these out?
Is it just a case of squirting some WD40/GT85 and let it soak for a while? didn't want to jump in feet first as carbs are a bit of delicate thing...
Pleased I'm following the guide, Emulsion tubes were all back to front and pilot screws were screwed all the way in...
Austin
Practical Sportsbikes
Re: Seized Carb Screws!
Posted: Mon Jan 23, 2012 10:00 pm
by petrolhead19
I had had same problem alot of times, quickest and easiest way, get some mole grips and clamp them round the head little tug and they will come loose, doesnt damage the screws so your safe there :D
Posted: Mon Jan 23, 2012 10:21 pm
by Drunkn Munky
As above then replace them with allen head screws, rick oliver sells a kit. The original screws need a special japanese screwdriver, JIS type i think there called although a posidrive usually does the trick
Posted: Mon Jan 23, 2012 10:34 pm
by Variablevalves suck
If you go with allen heads be careful when you tighten them up as you can easily over tighten and crack the carb body.
Posted: Tue Jan 24, 2012 12:02 am
Drunkn Munky wrote:As above then replace them with allen head screws, rick oliver sells a kit. The original screws need a special japanese screwdriver, JIS type i think there called although a posidrive usually does the trick
Yes there a JIS size #2, the screws can be quite tight and unless you have the proper screwdriver it's very easy to round them off.
With the proper screwdriver it wont' camout when putting a lot of force on to undo.
Posted: Tue Jan 24, 2012 9:42 am
by MostyVFR400
Cheers guys, i'll give the posidrive and mole grips a go, and throw a little patience and care in there.
Hopefully they will give in and come out...
Austin
Posted: Tue Jan 24, 2012 11:12 am
by thunderace
I found a #2 posi Snap-On screwdriver is the exact pitch and size for these :peace:
