Swingarm/Proarm Nut
Spotswood
Swingarm/Proarm Nut
Post by Spotswood »
As the title says...can someone advise what size the gigantic nut is for the swingarm? You know the one...castle nut on one end and gigantic nut on the other end by the rear set...it would save me a drive home if anyone can answer..thanks in advance! :D
elrikos
Re: Swingarm/Proarm Nut
Post by elrikos »
46mm if i remember correctly
I thought it was 38mm?
Or am I thinking of a different nut
elrikos
Post by elrikos »
if its the one i'm thinking of (the one on the sprocket side of the rear hub) then i think its 46mm. hold on i'll go and have a measure ( i am that sad!!)
elrikos
Post by elrikos »
yep for the nc30 its 46mm.
Spotswood
Post by Spotswood »
OK if anyone is still up (it's only 330pm here :D ) I'm confused elrikos...do you mean the axle nut? Beacuse I'm talking about the where the swingarm bolts through the frame right by the counter shaft sprocket and 46mm seems a bit too large for that but just right for the axle.
Spotswood
Post by Spotswood »
I guess everyone is passed out so I'm going to try the 38mm...note to self...keep reciept this time :roll:
Spotswood wrote:I guess everyone is passed out so I'm going to try the 38mm...note to self...keep reciept this time :roll:
go for the 38mm :) (thats the one that needs 165nm of torque)
+1 with Neosophist..
the other guys are getting their hubs and swingarms mixed up...
Spotswood
Post by Spotswood »
Never made it to the store in the end but I had a look at the nut last night and it looks closer to a 27mm? If anyone can check again to see what size socket I need that would be very helpful :scared:
