anyone used a carbtune on a v4?
leerc
as above-are they easy to use and are they actually helpfull for getting the carbs set right
lizard821000
Re: anyone used a carbtune on a v4?
i just bought one, ill let you know.
scotjell
- Bike owned: VFR400 NC30x2
Easy enough to use, but ensure you have a bucket of ice for putting your hand in after you burn it trying to adjust the screws. Recommend buying the proper adjuster tool which is a screw driver/socket at 90 degrees on a long shaft!!
Just found this it states not for Honda, but from my experience the screws on the carbs are slotted or you can use a small socket I think 7-8mm. item number on flea bay 390349421203.
lizard821000
scotjell
yeah that's why I showed the other one and busters do a set for £50, but I'm sure the Honda one I've seen in the past looks like http://www.ebay.co.uk/itm/Motorcycle-Ca ... 5ae2a37a93
lizard821000
do you adjust the butterfly screw to sync carbs? or the airscrews?
You adjust screws on the linkages that connect each carbs throttle butterfly. Probably impossible without a right angled screwdriver!
lizard821000
In that case, think ill purchase one lol cheers
spud
- Bike owned: vfr nc30 1990 , yamaha rs 100
heres were i brought this
http://www.machinemart.co.uk/shop/produ ... =SRC-right angle screwdriver
bargin in my eyes at £20
spud
spud
- royster81
Get your hand in there with a7mm socket, a pair of marigold help deflect the heat too.
