Strange Electrical Problem
Posted: Fri Nov 25, 2011 1:49 pm
Back again.
NC24 has been running sweet for about 6 months after fitting the new R6 Reg/Rect
A couple of weeks ago I noticed some strange things - I would turn the key and no lights on panel.
This happened a couple of times when getting on the bike after leaving it at the station for the day.
Take off side panel to view battery connections - wiggle a bit - it would come back
Start bike and away no problem
Then one morning started bike - Rev Counter shot up to Max and was going mad - up and down although the bike was idling at low revs - this settled and went away
The one night had to get breakdown out to get me started - battery was low - being drained by some problem.
He checked charging all looked fine
I charged battery at home and all is fine - battery appears fine
Yesterday was the final straw - got on and started fine - Rev counter went mad again and the bike felt very strange - severe lack of power - could only ride with low revs - Main lights were fine but indicators stopped working.
Got home, when stopped the bike it just conked out - dead - no electrics - pushed into garage - measured battery - still above 12.5V - so holding charge fine
had a quick check of wiring around battery area - looks fine
It does appear to be some short somewhere which drained the battery and is now causing all sorts of weird things - I suspect the wiring at the front under fuse box - which I can't get off - screws appear to be welded tight
Just wondering if any ideas - is there any other part that might cause this fluctuation of power.
Now that it has died - should I be looking at fuses - disconnecting/connecting wires until I see some life to find the culprit - is there a preferred plan to diagnosing the electrical circuit
