3TJ motor's
				petrolhead
3TJ motor's
Are motor's to fit a 3TJ hard to come by ..
I have tryed e-bay and cant find one to fit the 3TJ ..
I think my motor might be shot...the timing chain has slipped ..
I didn't take the head off yet to see the damage but when I look down the spark plug hole I can see the track of the valves on the piston ..(not good....lol)
So figured a new motor would probably be cheaper than a rebuild ..
Also does a 600 Fazer (02) head fit directly onto the motor ,
- Kayla850
- Bike owned: Sunn Tzar S2
Re: 3TJ motor's
Oh, that's bad newspetrolhead wrote:Are motor's to fit a 3TJ hard to come by ..
3TJ engines tend to be hoarded (and blown up!) by racers, a 600 conversion is the easiest/cheapest fix I reckon if you just want the bike up and rideable relatively quickly.
I've got no idea if the 02 Fazer head bolts on to the 3TJ, but I'd imagine the bore would be different and the cam timing would be all wrong for starters.
www.projection-racing.com
www.pjcfasteners.com
Re: 3TJ motor's
Yup I'd do a 600 conversion.
I think the 600 head would probably fit but the volumes are different. You can probably use a 1WG head (there a couple on e-bay) but really it's less work putting a 600 in.
				dobbslc
Re: 3TJ motor's
Are you sure the "tracks" in the pistons aren't just the valve cutouts that are machined into them?
Worth checking the timing just in case it only slipped a tooth or two.
				petrolhead
Re: 3TJ motor's
Wont know fully util I get the head off dobbslc about the valves touching ,but the timing seems to be a good bit out ,dobbslc wrote:Are you sure the "tracks" in the pistons aren't just the valve cutouts that are machined into them?
looking at around 6-8 teeth... Came on the problem ,last owner done a bodge job on cam chain tenisioner by putting a blob of weld on it ,which burn into the cam chain slide ..
				Taggyd
Re: 3TJ motor's
ive got a couple of 3en1 heads if you want to try one. just cover post, i'd rather it get used than be weighed in for scrap like it will very shortly!
				petrolhead
Re: 3TJ motor's
Thats dam sound of ya Taggy..Taggy wrote:ive got a couple of 3en1 heads if you want to try one. just cover post, i'd rather it get used than be weighed in for scrap like it will very shortly!
 But think the 3en1 head wont bolt to the frame of the 3tj but will look into it to make sure .
thanks a million
				Taggyd
Re: 3TJ motor's
ahh yep, forgot they dont have the same mounting, oh well, hope you get somethin suitable sorted!
				wedge
Re: 3TJ motor's
what be a fair price for a running 3tj motor with all electrics?????
						- Hogdigerdy Dog
Re: 3TJ motor's
alot more than a 600 lumpwedge wrote:what be a fair price for a running 3tj motor with all electrics?????
