Koso Speed settings, well off!
Posted: Sun Oct 09, 2011 9:07 pm
Right so the problem is Ive got the standard speedo cable with a digital converter plugged into the back of the RX1n
The setting options I have are wheel circumference between 1000-2500, with sensor points 1-6
According to digitalspeedos guide you have to spin the wheel one revolution and see how many times the cable turns. In this case its 1 turn of wheel = 2.5 turns of cable. Its then said you have to times this figure by 6 to get the correct number of sensor points is 2.5 x 6 = 15
So the wheel has a circumference of 2001mm and sensor point 15.
I can only set the sensor points to a max of 6.
Even if I work it out as a ratio I get about 800 to 6 which is now lower than the smallest wheel circumference setting.
Anyone if one fitted know how they have it set up? Or can anyone think of any clever ways to reduce the ratio of cable turns to wheel. As not only is the speed quite a way off so it the odometer.
