getting throttle to snap close? extra spring.
Posted: Sun Oct 02, 2011 9:02 pm
by Sligeach
My throttle stays open when i pin in it back. Cables are new and lubed and routed correctly but it just won't snap back closed when i let go of it.
Is there some mod i can do to make it close better, like an additional spring or something?
I don't mind it but not sure it will pass an MOT like this.
Re: getting throttle to snap close? extra spring.
Posted: Sun Oct 02, 2011 9:51 pm
by Man_Named_Dave
When mine was like this I sorted it with the adjuster at the handlebar end.
Posted: Sun Oct 02, 2011 11:42 pm
by Sligeach
What do you mean?
Put more tension on the return cable on the handlebar end?
Posted: Mon Oct 03, 2011 12:48 am
by LITTLE=ONE
check your twist grip tube (where your hand goes)is not stopping in from returning or the bar end weight is not binding
Posted: Mon Oct 03, 2011 4:17 am
A modification isn't necessary if it's working properly.
This indicates a fault somewhere.
Diagnose it!
First off.. disconnect the throttle cabes from the carbs... can you turn the butterflys at the carb fully open and do they spring back ok?
This elimates your carbs.
Now remove the throttle cabels from the twist grip and pull them by hand.. do they spring back? If not then it's a cable / routing problem.
If they do then it's a twist-grip issue.
Perhaps the grip is catching on something? Is it all clean and lubricated?
I've seen it a few times on bike, usually down to knackered cables or twist grip problems but as you said yours are new then it's likely to be the twist grip
Posted: Mon Oct 03, 2011 8:23 am
by amorti
Definitive checklist; in order of difficulty to check:
Is grip binding on bar end or throttle housing?
Is bar corroded or dirty under twistgrip?
Are cables adjusted too tight?
Are cables stiff, damaged, or pinched?
Are carbs damaged, missing a part , or corroded?
It will be one of those.
Posted: Mon Oct 03, 2011 9:02 am
by porndoguk
Dec also check that your handle/clipon isnt bent, its not rare for them to seize after a bar warps/bends thus causing it to stay open,
Posted: Mon Oct 03, 2011 9:10 am
by arsey30
Sligeach wrote:My throttle stays open when i pin in it back. Cables are new and lubed and routed correctly but it just won't snap back closed when i let go of it.
If this has occurred after fitting new cables make sure they are not crossed over and there is sufficient free play at the grip.
Posted: Wed Oct 05, 2011 12:13 am
by Sligeach
Spot on. Karma to you bro. Checked but the other bits and then let the tension of the top cable - the easier one to get at with the cabs still attached and as soon as i put some slack it in it was instantly cured.
Lubed the clip-on for good measure but it is working spot on now.
