NC29 Jetting
Posted: Sat Sep 24, 2011 2:54 pm
Hi to all, have been reading through loads of posts here and have established (I think), that my bike is running a bit rich.
Starts and ticks over fine, good pull on the flat until I hit 7k then it starts to splutter. Also, I have a slow turning uphill section on my road and when I pull the throttle to get up the hill it just bogs down and struggles. I have tried a stock air filter and the bike was almost unrideable. Have changed the plugs and oil/filter and cleaned and replaced the K&N.
The bike is a NC29L, I have a aftermarket stainless 4-1 fitted with a standard end can, and there is a K&N insert air filter fitted. Have had a look in the carbs and the main jets are 116's.
Can anyone tell me if this sounds like the right jet size for whats fitted?
If so, can anyone suggest what else to try to cure the problem? If not, what size should I have? and where might be the best place to supply them?
Many thanks to you all in advance, this forum in a mine of information.
