41mm Rear rider sag - Leave it as it is?
Posted: Tue Sep 20, 2011 8:00 pm
I see most sites recommend 35mm as a good figure for the rear sag, I've measured mine tonight and it's about 41-42mm (mate has trouble with the tape measure!) I've got about 8mm static.
This is a 1989 bike with 24Km and the original shock with the preload wound up to 6 (although it looks like there may be a 7 setting on it?!) Anyway, I'm probably about 95Kg with all the kit on and my fat frame
, previous owner had modified something to jack the back up already, so I know it sits slightly higher than standard anyway.
My question is, is it worth doing anything about it, or can I get away with 42mm? I'm a new rider so will not get anywhere near the limits of the bike for the foreseeable future, so I'm pondering whether to just leave it alone?
I'm planning on getting the Rick O front fork rebuild kit (for the K-Type forks), will this have any effect on the rear sag figure? Would it make it worse?
Finally, if it needs sorting, can I just get a slightly stiffer spring?
Thanks all
Thanks all
