should an NC30 start without choke
philfingers
Bike owned: NC30 Type 7
Post by philfingers »
just got my bike. previous owner said it always starts without need for the choke. is this correct, it's an import and from what i've read they run a little leaner. It does indeed start without choke, will tickover right from the off and doesn't smell rich. std can. Seems to run ok through the rev range tho does feel a little rich/wooly
I've yet to remove the tank, i will in due course strip and clean the carbs as a matter of course and reset the balance. I have an ultrasonic tank and compressed air for a good clean out.
Chrissy_J
Bike owned: VFR400Z NC21
Re: should an NC30 start without choke
Post by Chrissy_J »
The short answer is NO. Most petrol motors need some choke when starting from cold, except in hot weather when the bike's been in the sun, the fuel and air (in the airbox) are already warm and a less rich mixture is needed to start.
A choke works by richening the fuel/air mix, this is done by closing some of the air passages.
A dirty or blocked air filter would do the same thing so I'd look at that first.
You should always regard any previous owner as being monkey-fingered buffoons from hades, with less mechanical skill or sympathy than a housebrick, because quite often they are ... so a quick check on the consumables is always a good thing, when you purchase a new vehicle.
philfingers
i will be checking out various bits in the coming weeks, including giving the carbs a full check over. Oil filter has a little surface rust on it but as the bike has only done 1000miles in 6 years the oil is still a little golden in coolour. brake fluids need changing and will give the brakes a cursory clean.
I will check the airfilter out. It was justa quick question, to make sure they don't all do it!
Out of interest do valve clearances need doing often? My mille for instance, they rarely need doing at the first 9k unless they're seen a lot of track or race use.
JIGGLYB4LL
Bike owned: cbr125, NC30
Post by JIGGLYB4LL »
Chrissy_J wrote: You should always regard any previous owner as being monkey-fingered buffoons from hades, with less mechanical skill or sympathy than a housebrick, because quite often they are ...
lol lol :lol:
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
None of my NC30, NC35, RC30 will ever start from cold without choke.
They may fire, but not catch.
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Post by Lane »
Motorcycles do not restrict the air passages, but enrichen the mixture using an additional fuel circuit.
An open throttle butterfly in the inlet provides too much restriction when extracting as much power as bikes do from small engines.
johnnie5
Post by johnnie5 »
Lane wrote:Motorcycles do not restrict the air passages, but enrichen the mixture using an additional fuel circuit.
this all depends on the bike
some use a conventional choke which restricts air
a lot use an enrichment circuit
