help rattling noise at low revs
joshmega
Bike owned: nc 30 zx6r sv650
Post by joshmega »
the last few times i have been on my nc 30, it seems to have quite a bad rattle at around 3 to 4000 revs and then seems to dissapear after ten minuites when its warmed up
any ideas
thanks josh
loljohnsonlol
Re: help rattling noise at low revs
Post by loljohnsonlol »
More than likely your exhaust gaskets, mine used to do the same untill I finally got round to replacing them.
joshmega
Post by joshmega »
Any idea how much these cost? And are they hard to fit thanks josh
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
Check that it is running on all 4 cylnders.
If 1 is not running at low revs, that piston will rattle.
joshmega
Post by joshmega »
how do i check thins?
arsey30
Post by arsey30 »
Run it from cold until it will tick over without choke.
Stop the engine and allow the exhaust to cool, but not the engine [a few minutes]
Start up and run at tickover or fast tickover and check each exhaust is equally warm.
Rev hard and check all are hot.
You can disconnect 1 plug at a time and see if it does/does not alter the engine speed, but fronts are hard to reach.
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
Not trying to be condescending but are you sure it's not a loose chain?
Mine had a rattle and I couldn't figure it out for ages, checked all the brackets, fairings and mounts to no avail. Then one day I decided to put it on the rear paddock stand, turn it on and let the clutch out (not the best idea but it was secured to the paddock stand) and the chain was bashing in to the swingarm making it rattle - same as you at higher revs you couldn't hear it.
loljohnsonlol
joshmega wrote:Any idea how much these cost? And are they hard to fit thanks josh
The gaskets are cheap, but prices do vary between shops.
Front gaskets are easy to replace, but the rear gaskets you have to drop the engine out to relace them (or so it seems).
Hadies
Post by Hadies »
Gaskets are about 2-4 pounds a pop. Depends where from.
The engine doesn't have to be dropped to do the rear gaskets.
joshmega
Post by joshmega »
done gaskets wasnt that going to try valve clearences now
