J51's or 8ZC's?
Posted: Wed Aug 10, 2011 5:23 pm
by BillingCBR
Hi all,
While I have the '30 to bits trying to find out how broken it is, I've overhauling the carbs and fitting my NC24 slides. I don't have £40 spare to buy RO needles, so need to make a choice between stock '30 or stock '24 needles (as titled) I know the J51's are longer, but don't know how that'll affect the running of the bike by mix and matching.
Any advice please?
Re: J51's or 8ZC's?
Posted: Wed Aug 10, 2011 8:48 pm
by royster81
Stick with stock, they are that length for a reason.
Re: J51's or 8ZC's?
Posted: Wed Aug 10, 2011 8:56 pm
by Martin
^^^^ If you did use the NC24 needles, because they're longer the bike will run leaner.
Re: J51's or 8ZC's?
Posted: Wed Aug 10, 2011 10:11 pm
by BillingCBR
Martin wrote:^^^^ If you did use the NC24 needles, because they're longer the bike will run leaner.
Pretty sure the J51's are longer
can't remember as they're in the carbs now, but know I put the J51's back in
Re: J51's or 8ZC's?
Posted: Thu Aug 11, 2011 12:06 am
by Cammo
The 8zc's are much shorter and will run very rich in nc30 carbs.
They're a similar length to the nc30 hrc needles.
Re: J51's or 8ZC's?
Posted: Thu Aug 11, 2011 12:24 am
by BillingCBR
Cheers Cammo, I'm running stock intake flaps, snorkel, box etc so no need for the 8ZC's
When I have more money to throw at it I'll get some of Rick O's needles and go from there
Re: J51's or 8ZC's?
Posted: Thu Aug 11, 2011 12:43 am
by Cammo
Sounds like a good plan!
Re: J51's or 8ZC's?
Posted: Thu Aug 11, 2011 6:21 am
by Martin
Sorry getting confused with what goes in where but you knew what I meant
Re: J51's or 8ZC's?
Posted: Thu Aug 11, 2011 12:33 pm
Martin wrote:Martin wrote:^^^^ If you did use the NC24 needles, because they're longer the bike will run leaner.
The stock NC24 set-up is awfully close to the NC30 HRC setup.
I think the NC24 runs smaller air-jets than on the NC30 though? I can't remember off-hand though.
I'd imagine without airjet correction it'd run too rich in the NC30 carbs.
I have 51a/b's in mine and it runs fine
