Is there a Collet/flow reducer/ring inside exhaust manifold
Posted: Fri Jul 29, 2011 7:32 pm
Hi,
I have a clunking/rattling inside the exhaust manifold where it just becomes the one pipe. The manifold is a standard mild steel Tri-arm 4-2-1 (as far as I know), Basically there is a large piece of metal rattling about inside it, which is larger than the exit pipe. Unfortunately it is round the first bend and can't be seen with a torch so I have know idea what it is.
Was there a flow reducer ring of some sort fitted inside of these headers? I suspect what ever it is could potentially block the flow which obviously isn't good for the engine. Before I chop the manifold open to remove it and get it welded up does anyone have any idea what it could be?
On the subject of manifolds, when removing them 5 studs came out of the head with the nuts rusted solid to them. I have some stainless steel threaded bar of the right pitch I am going to use as replacement studs. My question is should the studs be screwed all the way into the head before the nuts are installed? It appears the genuine/original studs can't have been screwing until they bottomed out because of the step in their shank.
Thanks very much
Adrian
Thanks very much
Adrian
