VFR 400 NC30 MASSIVE HELP NEEDED!!!
Posted: Wed Jul 20, 2011 6:26 pm
by Causon67
I am currently rebuilding my NC30, I was about to put the colour onto the fairings when things when bad :cry: and after trying to repair my cracked fairing that has recracked and I now need to buy a new one as I fear if I repair it, the crack will reappear due to flexing under normally driving pressures. Does anyone know where I can get an orginal top fairing from? I know that Skidmarx do one for £114.95.
Many thanks Pete.
Re: VFR 400 NC30 MASSIVE HELP NEEDED!!!
Posted: Wed Jul 20, 2011 6:44 pm
by CRM
if you cant wait then that will be the easiest and cheapest option.
Posted: Thu Jul 21, 2011 10:41 am
by porndoguk
Causon67 wrote:I am currently rebuilding my NC30, I was about to put the colour onto the fairings when things when bad :cry: and after trying to repair my cracked fairing that has recracked and I now need to buy a new one as I fear if I repair it, the crack will reappear due to flexing under normally driving pressures. Does anyone know where I can get an orginal top fairing from? I know that Skidmarx do one for £114.95.
Many thanks Pete.
just q bond properly using a dremel to do the prep work, and then reinforce the back with fibreglass its all in the prep work, make sure you sand/abrase all the areas that the fibre glass is going onto, ive seen so many people stick fibre glass ontop of fresh paint and then wonder why it still cracks etc.
Posted: Tue Aug 02, 2011 7:20 pm
by GIXERMARK0
hi
if its abs plastic then get some fine wire mesh anduse a soldering iron to push the mesh into the plastic
once done then fill with fiber glass ect
iv been doing this for 20 years and works every time
when i wrote of my gixer the repair was stronger than the rest of the fairing
