NC30 Shift Light - Any Ideas
Posted: Thu Jun 23, 2011 5:41 am
by 999Gomerz
I am a bit of a tossa, I like a shift light.
To save me figuring out what makes the taco work etc. Has anyone fitted a DIY shift light to the NC30 ?
Cheers,
Re: NC30 Shift Light - Any Ideas
Posted: Thu Jun 23, 2011 5:57 am
by Cammo
I've seen one of these used on an nc30. Aussie made, good bit of gear:
http://www.ecliptech.com.au/
From memory it reads revs from the coil, not the tacho. I think installation instructions are available on their website.
Posted: Thu Jun 23, 2011 6:14 am
by lukemillar
I have one of these:
http://www.xtracing.com/en/gpxpro/index.php
Which has a lot more than just shift lights! However, it may be worth the extra $$ stretch? The data logging side of things is pretty sweet and a GPS laptimer speaks for itself!
This runs off the coil as well. You can also calibrate rpm/speed per gear and get a gear indicator as well.
Posted: Thu Jun 23, 2011 8:08 am
by mintmansam
theres is a picture of a shift light on a vfr on this site, its same shift light as someone else posted, just thought you might wanna see what it looks like on a vfr
http://www.fluke-motorsport.co.uk/shift ... -1040.html
Posted: Thu Jun 23, 2011 8:43 am
by 999Gomerz
I found this;
It expains what is needed to build a similar thing to the ones listed, not all the features, but similar thing?
http://foz11.tripod.com/DIY_MOD_s/Digit ... peedo.html
Posted: Thu Jun 23, 2011 11:32 am
by Smev
I think Rick Oliver sells shift lights.
Check out his stocklist in the V4 general section
