trouble fitting modified dog bone linkage
Posted: Wed Jun 22, 2011 1:06 am
by Spike16
Hi people
Iv been having trouble fitting a linkage I modified recently to raise the rear ride height up to where id like it so it feels a bit more like my race bike.
the linkage iv used has the hole redrilled 15mm further along the linkage, the issue im having is with the nc30 linkage should I loosen the bolt where the shock mounts the linkage and re-do at a different angle? to allow for the change in dog bone size?
also im finding the excess material on the end of the dog bone fouls on the standard system, should I just cut this bit off?
cheers guys
Re: trouble fitting modified dog bone linkage
Posted: Wed Jun 22, 2011 1:09 am
by Cammo
15mm is too much Spike, doubt it will fit.
It should be closer to 8mm, perhaps 10mm max (centre-centre measurement from original hole).
Posted: Wed Jun 22, 2011 8:40 am
by amorti
Do remember that when rising the back, you change the suspension geometry, particularly the chain tension required. It'll be slack as a 2$ whore at rest, then pull tighter all the way through the suspension stroke.
Posted: Wed Jun 22, 2011 10:03 am
by Spike16
ok so 15 was a bit optimistic? not to worry il get it re-done
Yeh I know what im doing changing the stuff, iv raced there 400's for 2 years now but each of my racers has had a longer rear shock and I just want the rear ride height to be similar to my racers as they have killler handling.
Posted: Wed Jun 22, 2011 11:43 am
by CRM
15mm - that'l sharpen the steering up a bit. ;-)
Posted: Wed Jun 22, 2011 2:29 pm
by Spike16
haha yeh well im also doing a 17 rear so that will drop half inch, point take will back to drawing board and get a 10mm one made
Posted: Wed Jun 22, 2011 10:21 pm
by reverse cylinder jim
Spike16 wrote:haha yeh well im also doing a 17 rear so that will drop half inch, point take will back to drawing board and get a 10mm one made
Think it might be easier to just buy one from Rick Oliver. That way you know its the correct.
Posted: Thu Jun 23, 2011 12:51 pm
by Spike16
Id love to buy one but all of my $$ goes into racing, im fixing this thing up on the cheep for the moment while I start my placement, its a proven mod just takes a bit of time to get right which I dont mind if its gona be free :)
