Page 1 of 2
Goodridge rear brake line nut removal
Posted: Thu Jun 16, 2011 8:13 am
by STYLER
Can the thin nut behind the large loose one be un-screwed and removed or is will it be crimped on etc?
Im putting the line through the swing arm. I know you can do it without removing the joint but thought it may look neater with a smaller holes in the swinger.
cheers peeps
Re: Goodridge rear brake line nut removal
Posted: Thu Jun 16, 2011 8:33 am
by lizard821000
i dont think it can be removed mate tbh. its part of the line...
Posted: Thu Jun 16, 2011 9:21 am
by porndoguk
no it cannot be removed,
i did a 20mm Dia Hole, pm me your address and ill post you some 20mm Black Rubber Grommets,
make sure before you drill the holes you do it in the right place! most importantly the hub end one!
Posted: Thu Jun 16, 2011 9:58 am
by amorti
Posted: Sun Jun 19, 2011 9:19 pm
by Chrissy_J
I don't think it's a nut! It's part of the fitting; it's hexagonal so's it's easier to assemble, you tighten the big nut against it when you fit the banjo.
It can be removed but you'll need a new olive and the fitting to be remade. TBH I'd rather have a bigger hole in the swingarm, than to fiddle with a factory fitting.
Posted: Sun Jun 19, 2011 9:28 pm
by porndoguk
Chrissy_J wrote:I don't think it's a nut! It's part of the fitting; it's hexagonal so's it's easier to assemble, you tighten the big nut against it when you fit the banjo.
the Goodridge NC30 Hose wont need shortening, mine didnt its just the right length youll see in my pics of my rebuild.
Posted: Mon Jun 20, 2011 6:12 pm
by lizard821000
MAY i ask the advantages of routing the rear line this way?? i bought some HEL lines and routed normally where the old went, brake works good and looks fine. just curiouse really??
Posted: Mon Jun 20, 2011 6:16 pm
by Hadies
Just for looks I reckon.
Posted: Mon Jun 20, 2011 8:33 pm
by porndoguk
Cosmetic i guess, but i did want rid of the hideous honda chain guard, but now i have a Carbon Hugger, so im back to were i started i guess.
Posted: Mon Jun 20, 2011 9:12 pm
by amorti
Hadies wrote:Just for looks I reckon.
Tht's all. In fact it'll be worse performance wise because it's a pig to bleed a line with so many ups and downs, but it really does look aces.
