				Flat Battery !!!!!!!!!!!!!!!
				Posted: Wed Aug 06, 2008 8:35 am
				by BrownyNC29
				My battery keeps going flat or not having enough charge to start my bike so I am having to jump start it, is this just a case of a dud battery or is it the reg/rec ? or maybe even the alternator ? what does the reg/rec do ? if its dead which one should I buy as I have heard the yamaha ones are better but not sure which year model to use ? any ideas guys :-)
				Re: Flat Battery !!!!!!!!!!!!!!!
				Posted: Wed Aug 06, 2008 1:14 pm
				by leopard_pagan
				reg/rec job
it regulates the power created from the alternator that gets charged in to the battery and then rectifies any spikes the charge.
cant say on the yam Reg/rec.
how old IS your battery? over 3yrs old?
if so time for a change anyway.
test the bike for battery output while bike is switched off/idle and revving.
post the voltages up as the readings will tell if reg/rec is on its way out.
				Posted: Wed Aug 06, 2008 1:33 pm
				by BrownyNC29
				leopard_pagan wrote:reg/rec job
not sure how old the battery is I have had the bike since decemeber but the battery is probably over 2 years old at a guess I have bought a bettery tester today which when the bike is running will tell me if the alternator is working if it is does this mean its the battery not the rec/reg ?
				Posted: Thu Aug 07, 2008 6:59 am
				by leopard_pagan
				if it gives you a voltage reading.. stick the probes on to the battery and post up here what the readings are for:
bike switched off: ..........V
bike started up and on idle:..........V
Bike revving up and held at a higher than idle speed:..........V
with those readings people here can tell you more. i just know that is the info they need.
