Page 1 of 2
				400 Engines
				Posted: Wed May 25, 2011 1:55 pm
				by eabeukes
				Hi all
Been lurking a bit round here, recently picked up a shaggy 3EN2 that turns out has no compression. I;ve been quoted £300-400 for a full rebuild, but I'm wondering if it's not just easier to fit a replacement 400? Where do people buy these, have looked on fleabay and gumtree but they seem ot be thin on the ground!
				Re: 400 Engines
				Posted: Wed May 25, 2011 2:24 pm
				by Evilchicken0
				welcome to the forum
Ok there are 2 main reasons for no compression.
Most common is the valves have run out of tollerance and are touching the camshaft so they're always open. If you can read a manual and do some mechanics then you might tackle this job. The problem is the valves can become deformed and you need to take the head off to change them.
Second reason is the piston rings/ bores have worn out this would be a top end engine rebuild.
3en2 & 3en1 engines are a bit thin on the ground as you've just found out and even if you do get one you could face the same situation that your in now. So I'd look for a 600 motor from a FZR600 3HE - we have a thread running on this swap
viewtopic.php?f=35&t=26259 and look to do a coversion.
We need pictures though .... we always need pictures
				Re: 400 Engines
				Posted: Wed May 25, 2011 2:43 pm
				by eabeukes
				Thank Evilchicken
Have been keeping an eye on the conversions, I think I may need a shed to do it in first! That and maybe a grave in the garden for when i bring it home for the wife to see...!
Is the 600HE the only model that will fit? Or can other engines be machined to get in? Just wondering as there are a couple of FZR600 engines on ebay but no model numbers further.
				Re: 400 Engines
				Posted: Wed May 25, 2011 2:59 pm
				by Evilchicken0
				There are two types of 600 as you've pointed out, you want the 3HE or the one with fins on the top side of the engine.
The other type is the 600R, 4JH, Foxeye or ThunderCat engines they're smooth on the sides.
Depending where your based you might find a local "man in a shed" or "race rider" who can do the valves more cheaply than a garage.
				Re: 400 Engines
				Posted: Wed May 25, 2011 3:03 pm
				by eabeukes
				Re: 400 Engines
				Posted: Wed May 25, 2011 3:56 pm
				by Evilchicken0
				Um .... there's always an exception. The FZS600 Fazer used the later 4JH engine with the fins, it might go into your frame but I'm not certain the sprockets would line up.
What you need is something like
http://cgi.ebay.co.uk/Yamaha-FZR-600-EN ... 1e63de5fe1 you can pay about £100 for one but you'll need all the other bits too.
				Re: 400 Engines
				Posted: Fri May 27, 2011 11:35 am
				by eabeukes
				Evil - is the valve stuff you are talking about on page 3-8 of the manual? What could I use in place of the 'specialist' tools listed?!
				Re: 400 Engines
				Posted: Mon May 30, 2011 7:15 pm
				by Evilchicken0
				dont have the manual so not sure but the only special tool that would be useful is a cluch holding tool so the engine doesnt move when you lift the cams
				Re: 400 Engines
				Posted: Sun Jun 12, 2011 7:56 am
				by gillingham
				Heya, just seen your post code on the for sale section, I'm in KT2! If you need it there's a garage with bike ramp and lots of tools and a couple of student engineers who are both proficent at re-building engines availabe????
Adam.
				Re: 400 Engines
				Posted: Tue Jun 14, 2011 12:57 pm
				by eabeukes
				Awesome - I think I can get a 1WG engine for 'nuts - anyone know if it will bolt into the 3EN2?
