Relocating the reg/rec
Posted: Sun May 15, 2011 8:22 pm
Hi all,
Recently, my reg/rec went bad, so, i followed the advise most of you suggested in this forum.
Replace it with a R6 one. And i did. I bolted it on the usual spot that we all know and it worked great...but there was a slight problem.
The reg/rec was bigger and it created a big crack on the tail fairing, needless to say that it was overheating because no air could come in and eventually go out.
So i decided to relocate it and i must say that the outcome is nice. The location is under the pillion seat as you will see in the following photos, you can also see the s/s base and how the reg/rec fits finally on the bike
In the following photos you can see the s/s base and how the reg/rec fits on the bike....
In the next photos you will see two tubes...they will dissipate hot air from the reg/rec compartment...an 8x8cm fan will be installed soon of course...
There had to be made some small mods on the pillion seat for example and few other places, for the base to fit but they where as i said....small, and very easy to do.
