Hrc Fuel Tap Vacuum build up diaphram problem???
Posted: Thu May 12, 2011 8:33 pm
Ok im asking this question for a friend in the philippines that one:: Doesnt have internet access Two:: Speaks bloody bad english
So my mate has a Track NC with "the" tap mod, He did 4-5 races with no issues and now from what I can understand, the Diaphram is being pulled away from the round plastic spacer in the tap inself causing the fuel channel to be blocked... So he said he has taken the tap apart again pushed the rubber diaphram through the plastic spacer all fitted up and the bikes works A1.. Then after being stood for half a day the Diaphram has been pulled off the spacer again!!!!
The only thing I could think of that would cause this would be a vacuum build up in the tank causing the diaphram to be "sucked" back into the fuel hole!!! Anyone else had this issue???
I myself have run this mod for sometime now with no issues and I havent heard of it happened before?????????
Please dont turn this into a flaming thread regarding this mod either!!! Help need only
