NC30 Shock options
Posted: Mon May 09, 2011 4:17 am
by 999Gomerz
Hi Everyone,
My name is Adrian and I picked up an NC30 on Saturday. I am from Melbourne in Australia.
It is an 89 Model I think as it has the single adjuster forks and crappy shock.
I have been riding track days for a while and want to get started in racing, I am an OK rider but want to improve my riding skills which is why I got a 400.
I would like to replace the shock with something off a later model bike a honda 600-1000, preferably a showa one, also would like to get the forks a bit more adjustable and set up.
I have sent Rick Oliver an email about the forks, but have a question about the shock
What other shocks can I replace the standard one with minimal modification, ie 2004 CBR600RR, 2009 Suzuki something or other.
Your help is appreciated.
Looking forward to getting it running and out there to have some fun on.
Cheers,
Adrian
Re: NC30 Shock options
Posted: Mon May 09, 2011 5:05 am
by Cammo
999Gomerz wrote:I have been riding track days for a while and want to get started in racing, I am an OK rider but want to improve my riding skills which is why I got a 400.
Good move!
The late model suzuki gsx-r shocks seem to be the easiest to fit. You may need to fit a smaller battery for the remote res to fit in, but not much more to it. Even in standard form it'll be plenty better than a 20+ year old vfr shock. You can pick them up off US ebay for about $100 landed if you look around.
Good call looking into the Rick O fork upgrade.
Posted: Mon May 09, 2011 6:11 am
by 999Gomerz
Hi Cammo.
Thanks for your post,
There are two on ebay at the moment,
a 2007 for $170 landed:
http://cgi.ebay.com.au/07-Suzuki-GSXR60 ... 23106861e6
or a 2005 for $100 landed:
http://cgi.ebay.com.au/Suzuki-GSXR-600- ... 588dcce3d9
Which one should I get?
Cheers,
Adrian
Posted: Mon May 09, 2011 6:33 am
by 999Gomerz
I went and had a look at room around the top mounting point and it appeared as if the 2005 one woudl fit better as the reservoir was above the mounting point. So I got that one.
Fingers crossed it works!!!
Posted: Mon May 09, 2011 8:33 am
by Drunkn Munky
As far as I know you need a 2006 or 2007 600 or 750 shock to fit the NC. All other model\year shocks are different in some way so weather there fit or not I don't know but I do know the 2005 model is a massively different bike to the k6 and 7.
Posted: Mon May 09, 2011 12:26 pm
by 999Gomerz
Thanks guys.
I decided to buy both and see which one fits when it gets here, the postage was as much as each shock so combining them was a no brainer.
I will let you know how they fit.
Adrian
Posted: Tue May 10, 2011 6:11 am
by sil3nt
How does a GSXR shock affect the bike?
Does it raise/lower it?
I am assuming its quite a bit stiffer?
Fully adjustable?
Wouldn't want to buy one and find it totally screws up the handling!
Posted: Tue May 10, 2011 6:41 am
by Cammo
They're the same length as the nc shock. The spring rate is actually lighter than standard nc30 but you could always buy a heavier spring (or try and fit the NC spring), the valving will also be out because of the lower link arrangement. They're not adjustable for ride height.
Some on here have raced on them, so they can't be half bad. The main benefit is that they're newer, and a (much) cheaper alternative to an aftermarket shock.
I'm going to fit one to my roadbike next summer I think....
Posted: Tue May 10, 2011 8:00 am
by Drunkn Munky
Your need a tappered spring to replace the soft standard gsxr one, your see what I mean when they arrive, thinner at the top and wider at the bottom. About 850lbs depending on your weight
Posted: Tue May 10, 2011 12:15 pm
by ChowderV4
So the early shocks k4/k5 wont fit?
