NC23 Regulator/Rectifier plug burnt, and melted
Posted: Wed Apr 13, 2011 10:30 pm
by jetam
Hi, this is my first post. I purchased cbr400rr month ago, and i'm currently installing body kit form Tyga, so i have to relocate some electrical components. While moving regulator, one of the wires fall out, so i had to disassemble it. I hardly got it apart, and I noticed that plastic plug is burnt, and melted.
I have two questions
-have i accidentally burned somthing, or is this normal wear?
, before that motor worked normally
-I need new plastic plug, can i get it in any electronic store?
ill post some pictures tomorrow
Re: NC23 Regulator/Rectifier plug burnt, and melted
Posted: Wed Apr 13, 2011 11:16 pm
by Davez29
Hi jetam, possibility your reg is about to go the way of the dodo if it has not done already, get it checked. The burnt wiring and plug should be replaced your best bet is to see someone who can sort it properly as any bodging will just lead to more problems.
BTW my mates RC30 which is the nicest cleanest example you could find anywhere has just had the same problem, and his reg was working fine. Although he did tell me it was a common RC fault due to a localised build up of heat and a repair kit to stop this was available from David Silver.
Posted: Thu Apr 14, 2011 3:43 pm
by jetam
Thanks, I'll try to fix it somehow, until i replace it.
Is this the right regulator:?:
http://cgi.ebay.at/Regler-MOTORRAD-HOND ... 588d0bdc56
Posted: Fri Apr 15, 2011 10:25 pm
by Variablevalves suck
towzatronics on ebay supply exact replacement terminals motorcycles.
