running issues with my nc35 help?
Posted: Thu Apr 07, 2011 5:59 pm
hi all
My nc35 isnt running right. Il start by saying ive recently had the bike into Honda and had the valve clearances set and carbs cleaned and balanced had my jets checked at 108's. Ive had a new copy air filter from David silvers and pulled the foam inserts that line the airbox snorkel off. The bike starts and runs perfectly if you increase the revs slowly when riding it will rev right through however if your riding at a steady speed and open the throttle to pull away it bogs down and splutters it feels like its trying to suck in too much air, if you ease of the throttle it will clear and pull away up to top end, when the throttle is wide open and im reaching top end, again it bogs and splutters and i can feel it holding back then trying to go. I have to play with it on the throttle by backing it off and on to get it to rev out but even then it dosn't feel at its full potential
The all important flap under the snorkel is in one piece and correctly fastened down i had my slides out and cleaned them up and they open and close fine the only other thing i can think of is the foam bit that lines the snorkel of the airbox. Is it that important? i wouldnt of thought it would make a difference but its the only thing i can think of thats different, also the guy at my local Honda said '' it could be the air filter, as its a copy and not a genuine the air flow isnt sufficent'' is this true or is he just talking it to try and sting me for a genuine Honda filter?
hope some one can help as im pulling my hair out with this now
