Pilot screw adjustment
Posted: Thu Mar 31, 2011 4:36 pm
I think I understand how to adjust the mixture, ie screw in pilot screw till it splutters and is dying, screw out till you get to point where revs rise to a maximum. go past that and it will start to die again, screw back in till its at the highest idle. Then adjust the idle screw to suit.
My q is, when adjusting as there are 4 carbs and 4 pilot screws!! , do you
1)have to do 1 pilot screw, then just adjust all the others to whatever its screwed out to?
2) adjust all 4 pilot screws individually? ie 1 by 1
3) adjust 4 pilot screws but all at the same time, if that makes sense. ie incremental adjustments to all pilots.
when thats done, then you balance the carbs dont you.
Just trying to get it sorted in my head before i have a go.
