carb trouble!
Posted: Tue Mar 29, 2011 7:33 pm
Hi all, its been a while since iv been on here, the site has changed a lot & looks great, glad to see good advice is still being given as im in need of some. just over a year ago i had a bad accident on my winter bike so the nc30 has been sat idle for all this time, when i tucked her up she was runing perfect but on trying to start her at the weekend she dident want to go, i managed to get her started but she was backfireing and when i cracked the throttle open fast she would die, iv discovered that the front two cylinders had filled up with petrol so i took the carbs off cleaned them out checked the float heights and the float switches which all seem to be working as hey should, but when i re fited the carbs it done it again, has anyone got any ideas what if not the floats can cause this?
Any help would be greatly appreciated. my bike is a 92 uk mdel nc30 with nc35 carbs running the full hrc carb kit and airbox set up with a modifyed filter, im running 142/145 mj, hrc emulsion tubes, vell stacks, & slide springs, using the B needles on the longest setting, i allso use a small k&n crank case filter, nc35 cams, and a load of other mods but the above is all that would effect fueling. Thanks.
