Spluttering and dying on startup
Posted: Tue Mar 22, 2011 9:32 pm
I bought an RVF last year. Runs absolutely fine on a run however last year 2 maybe 3 times in the 2 months of running it, when left to warm up (without choke) it would start to splutter. I managed to catch it and gradually clear her out with some revs. Was as if the plugs were oiling up. It was worse when i used the choke the once.
I got it moted just over a week ago after not riding it since October. I started it every few weeks without a problem. I only did 7 miles after the mot as i had other commitments. This week i started her and she quickly started having this problem of spluttering only this time she died and i couldn't restart her. Pulled the tank off and noticed the fuel pipe from the tank was completely dry. Got some fuel down it and fired up a treat. Went off to an international mx meeting a fair way from home... come the end of the day she did it again. This time I switched the fuel tap to reserve and she fired up very quickly hurray
The tap has a diaphragm in it doesn't it? Therefore a vacuum pipe im guessing may be the problem? The thing i don't understand is surely it would misbehave on a run?? Its always on startup at low revs. Stopping at lights etc has never lead to problems. Any thoughts would be much appreciated. Thanks
