Steering stem adjustment?
Posted: Mon Jul 28, 2008 4:46 pm
Anyone have a special trick for adjusting the steeering stem (head race bearings)? Here's the problem. I can adjust the lower adjuster nut to the perfect spot, then when tightening the top lock nut I am "in between" two slots for the locking tab. What I mean is if I go to the looser slot/tab, it's too loose, and if I go to the tighter slot/tab, it's too tight and ends up moving the lower adjuster nut even tighter. I have tried it several times and I have tried using 3 different shock spanner tools but none of them fit too well because the nuts are smaller. I guess what I really need is someone to hold the lower nut while I go at the top nut, but I still think it will move the lower nut and the adjustment will be too tight. Been doing the build all by myself so does anyone have any better ideas?
EDIT: I should probably just go with the looser setting and after getting it on the road log a few miles and come back and re-adjust. Right?
EDIT, EDIT: Don;t mind me, I am just thinking out loud here. I suppose since I don't have the front end assembled and it's not bearing any weight that will affect the adjustment also, correct? OK, I'll just shut up now and wait until it's all assembled before I attempt any further adjustment. Thanks for all the help! :D
