cant get my carbs on,3en2
Hi, im really stuggling to pop my carbs on my bike and i have tried using wd40 but things wont go in. (worse than intercourse)
the rubbers are supple and I dont really wanna buy new rubbers if i can avaid it has anyone got any ideas to the get these things on.
- Sligeach
Re: cant get my carbs on,3en2
they do go on eventually with a bit of persuasion, the WD4o is a good idea.
try lining up the inside and the outside perfectly and then push the back of the carb rubber lip on at the back and then the front.
it does take a lot of jimmying but they do go on.............................eventually!!
what I used when my carb rubbers were really stiff was a paint stripper (or a hair dryer should work as well). Make sure the clamps are backed out as far as the can go, sit the carbs on and press down with all your weight.
NOT paint stripper !!!
It's caustic and will melt the rubbers - WD is petrochemical so that isn't great either (but probably won't hurt). silicon is best for this ... or lube
It's a biatch of a job - lube 3 of the inlets, then get one side in the unlubed and after that it's brute force and jiggling ... and swearing ... and anything else.
You feel good when the go in though.
then all you need to do is get the airbox on
- SHimmer45
- Bike owned: GPz500s KR1 KR1-S
surely if they are that stiff it might be an idea to get some nice new ones :D
Shirley ???
You can't get them.
You can't get them.
- Sligeach
Evilchicken0 wrote:NOT paint stripper !!!
i think you'll find he said a paint stripper, not paint stripper EC0
- Bike owned: Harley Sportster 883
Sod the consequences, smear some oil (I use two stroke) around the inside of the carb rubbers and the outside of the carbs. Don't go mad, just dip your finger in some oil and wipe it around the rim (oooh, that sounds a little dodgy, sorry).
It works though and I've never had any problems.
Ah I seedeclangaelic wrote:i think you'll find he said a paint stripper, not paint stripper EC0Evilchicken0 wrote:NOT paint stripper !!!
Silicon does the same thing as oil but it doesn't react with rubber and is safe even on Unique's rin... erm ... finger
Take off the top of your air box
And remove the filter
Put some sort of lube on the rubbers and line them up on the backs of the carbs
Stick your hand in the air box and push down on the front of one of the middle carbs and do up the clip for that one (Helpfull if you have another pair of hands)
Then do the other middle one, then the outside ones
I found this by far the easiest way
