nc30 died please help.
Posted: Sat Mar 12, 2011 10:33 am
by myheroduane
so i took the beast out for a blast yesterday and when i went to restart the bike dead battery. i bumped it and it was fine but 5 min into riding i lost 2 cylinders and 5 min after that(strugling to get home) going uphill it died. recovery van came and it fired up with the quickstart and then a couple minutes same lost 2 cylinders and then died. anyone ever had this happen?
Re: nc30 died please help.
Posted: Sat Mar 12, 2011 10:42 am
by Alex_ludd
i had a similar sort of problem turned out to be a bad frame earth id check these first, if they are fine and the problem persists id be looking at your charging system possible reg/rec failure.
there are more knowledgeable people on here than me im sure they will be along to help you out in the mean time do a search for reg/rec problems on this forum im sure you will turn up some helpful info
hope this helps
alex
Posted: Sat Mar 12, 2011 11:47 am
by ibby4585
3 things to check.
Battery
Coil packs
And rectifier/regulator.
My guess is the rectifier has had it. Check the connectors into it and see if they have burnt out or corroded.
Then give the battery a good charge and test.
Maybe that your battery is screwed too.
Could be earth strap too
Posted: Sat Mar 12, 2011 7:28 pm
by Man_Named_Dave
Sounds like what happened to me when my Reg/Reg failed.
I'd get it to a guy who can check the whole electric system.
Posted: Sat Mar 12, 2011 11:31 pm
by geebus
I had something similar. a wire from the rear brake melted onto my exhaust shorting the fuse. i had nearly no lights and no rev counter i think it was. That happening too? checked your fuses?
