Page 1 of 2
nc30 running rough at 6k
Posted: Mon Feb 28, 2011 3:34 pm
by pugparcels
right, quick run around the block this afternoon to check nothing falls off and i can stop when i need to etc, and i have found she is running really rough at 6k.
standard cut system with race can, 118 front & 120 rears, standard filter and pilots set to 2 & 1/4 turns as per cammo's guide. i took her out earlier last week and she ran rough then, however when i took the carbs off and checked the pilots i had set them to 2 & 1/2 ( god knows why? ) so when i put them back in earlier i set them to 2 & 1/4 and she seemed better but still not right.
so is it worther winding the pilots back in another quarter to 2 turns or should i being looking at something else as the cause?
both times she was warmed up for a good 10 mins before going,
Re: nc30 running rough at 6k
Posted: Mon Feb 28, 2011 3:46 pm
by alexwitham
Describe the issue - is it bogging down, revving slowly, not revving at all, miss-firing.
Your jetting seems about right for your spec, I had the same spec on my old NC30 with the same jetting and it was perfect.
Posted: Mon Feb 28, 2011 3:52 pm
by pugparcels
alexwitham wrote:Describe the issue - is it bogging down, revving slowly, not revving at all, miss-firing.
that would help! sorry i would say she is bogging down, nice and smooth up until 6k then she goes really rough through the 6 / 7.5 k mark. if you open the throttle more to counter this you 'run through' the bad spot then she keeps going and seems fine after this.
chris
Posted: Mon Feb 28, 2011 3:54 pm
by alexwitham
Well the NC's have a notorious flat spot around the 6-7.5k RPM mark so perhaps you could just be experiencing this?
Or is it really that bad?
Posted: Mon Feb 28, 2011 4:02 pm
by pugparcels
i have a flat spot on my fireblade, this is because i removed the butterfly valve in the exhaust for a straight through system i dont mind this minor flat spot for the other gains i got by doing this.
the nc is a bad flat spot, she really bogs down and it doesnt sound like bike coming around the corner it just sounds like a noise on wheels if i am close to or in that 6k area, i think i may try the original 2 turns on the pilot settings and see what result i get from that.
Posted: Mon Feb 28, 2011 4:40 pm
by Drunkn Munky
Are all rubber flaps/snorkles/filter in place?
Posted: Mon Feb 28, 2011 5:03 pm
by pugparcels
all flaps etc present. No air box mods what so ever. Been there tried that. Not doing that again!
Posted: Mon Feb 28, 2011 6:26 pm
by Drunkn Munky
double check your carb settings and check for signs of wear, its easy to get sidetracked and turn something the wrong way but if it was running fine before you started playing with it then chances are you've overlooked something.
Posted: Mon Feb 28, 2011 6:32 pm
by lizard821000
surley the pilots only effect idel?? or am i being a 4T noob here. im new to 4T so dont all 4 carbs work together? or come in at diff times or somin depending on revs.
Posted: Mon Feb 28, 2011 7:50 pm
by pugparcels
the only reason i am going to try the pilots on the original setting is because i noticed when i set it at 2 and a half then found an improvement on 2 and a quarter then maybe two turns out only may help improve things again. I have nothing to loose by trying it.
