nc29 - 39 tooth rear, is that all there is?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
As it says in the title really, chaps and chapesses.
I only seem to be able to find 39 tooth rear sprockets for the nc 29. I am putting nc29 wheels on my CB-1, which usually comes with a 41 tooth rear sprocket. It shouldn't make much odds because a 160/60-17 tyre is "shorter" than a 140/70-17 so in the end it'll about balance out, but it still surprised me that you don't seem to be able to get any other sizes?
chrisja2
Bike owned: nc29 trackbike
Re: nc29 - 39 tooth rear, is that all there is?
Post by chrisja2 »
You running a 525 or 520 chain Aaron?
Wozza
Post by Wozza »
Yes.
You have to options:
1) Convert to 520.
2) Buy a sprocket for a CBR900 96-99 (same as some 600s) - requires modification. The mounting holes on the NC29 sprocket are 10.5mm dia.; 12.5mm on the 900 sprocket. Parus had some studs made up with a 12.5mm central section between each thread; I made some spacers to fit the standard sprocket studs. I suppose another option might be to drill and tap the threads in the sprocket carrier so you can use 12.5mm studs.
Note these diagrams:
http://www.jtsprockets.com/52.0.html?&L ... uid=324&p=
http://www.jtsprockets.com/52.0.html?&L ... id=4875&p=
If you want a 42T CBR900 rear for the above I've got one I no longer need.
amorti
Regular Member
Post by amorti »
chrisja2 wrote:You running a 525 or 520 chain Aaron?
I think 525 is standard on both nc27 and nc29? Anyway, that one, as I am more interested in longevity than lightness.
veefer400
Bike owned: Ducati 900SS, 1978 Cafe 400/4
Post by veefer400 »
Im sure Renthal do different size alloy sprockets for a '29?
amorti
Regular Member
Post by amorti »
Wozza wrote:Yes.
1) Convert to 520.
A big THANK YOU!
Now there's an interesting idea. I have a spare CBR900 rear wheel in the garage, I could test the sprocket carrier on the nc29 wheel, never know, it might be as easy as that!
amorti
Regular Member
Post by amorti »
veefer400 wrote:Im sure Renthal do different size alloy sprockets for a '29?
Not sure either way - but I probably should have specified - I have less than zero interest in alloy sprockets.
Wozza
Post by Wozza »
I'm 99.9% sure they don't, not in 525. Strange I know.
amorti wrote:Now there's an interesting idea. I have a spare CBR900 rear wheel in the garage, I could test the sprocket carrier on the nc29 wheel, never know, it might be as easy as that!
Good idea! Let us know the result.
amorti
Regular Member
Post by amorti »
amorti wrote:
Wozza wrote:Yes.
1) Convert to 520.
A big THANK YOU!
What's even better, is that using that JT website I have figured out that if I can get that rear sprocket on, which I am sure it's possible, then the humble '04-'08 CBF500 uses the same front and rear sprockets as I would be using, so I could still pick up kits relatively cheaply rather than buying the component parts. Brilliant!
hallsie
Bike owned: NC29
Post by hallsie »
I got mine from GF and put a 15 40T combination on with a 520 pitch chain , I know Graeme had other rears as well including a 42T if I remember correctly as it's in one of my older posts .
kate beckinsale....... mmmmmmm
