RRJ wont play nice
Posted: Tue Jan 25, 2011 7:12 pm
Hi all,
To give some background,my CBR954 was stolen a while ago. Sadly my baby was uninsured and as funds are limited at the moment, I bought a CBR400 nc23 which had been standing for some time. Well this has lead to rather a steep learning curve as it turned from a quick fix into just about a full blown restoration.
I need some guidance please as I have reached the point of turning my bike into a Molotov cocktail because she wont start. When trying to start her, she will backfire through carbs and if I continue to crank it for any period, it will then backfire through the exhaust.
So far I have tried cleaning the carbs. The coils,HT leads, plugs, battery, rectifier and fuel pump have all been replaced and I have verified that the new parts are working. The fuel is also fresh.
From my understanding the backfire indicate's a lean condition, yet if I pull the plugs they are wet?
I suspect that the problem is carb related but that being said, the jets are standard size, float height's and idle adjustment are set as per the Haynes manual. I don't know what to check anymore?
Thanks in advance
Conrad
Thanks in advance
Conrad
